Crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Base on the revolutionary NVIDIA Pascal GPU architecture and cleverly designed for VR. It boasts high-specs and a variety of technologies to push your gaming limits to the max. There are various aspects to the cooling system embedded into the 1060 Xtreme Gaming GPU, that come together to create an impressive and effective heat dissipation system. This 1060 cooling features GIGABYTE patent-pending 3x 100mm stacked fans, unique blade fan design, double ball bearing structure, angular fin design and 6 composite heat-pipes with direct touch on the GPU. Experience higher performance at lower temperatures with the XTREME GTX 1060.
Clever layering of this 1060's fans has allowed for larger fans (100mm) to be installed, providing a larger and more smooth airflow. Compared to the standard 3x 80mm fans , the WINDFORCE stack fans create 10% enhanced cooling performance.
