- AMD Radeon HD 7750 Series
- Core/Mem clock: 880 (Std 800) / 4500 MHz
- 1GB GDDR5 128-bit memory interface
- PCI Express 3.0 x16 bus interface
- World's first 28nm GPU
- Supports OpenGL 4.2 / Shader Model 5.0
- AMD Eyefinity 2.0 Technology
- AMD CrossFireX™
- Support Native HDMI 1.4a (with 3D over HDMI)
- Support mini DisplayPort 1.2
Specification
- GPU: AMD RADEON HD 7750
- Core Clock: 880 MHz (Std 800)
- Memory Clock: 4500 MHz
- Memory Size: 1GB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 128-bit
- Stream Processors: 512
- Memory type: 64M x 32
- DirectX 11: Yes
- DVI Port: Dual-link DVI-D
- HDMI: Yes
- D-Sub: Yes
- HDCP: Yes
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a new standard by using ferrite core chokes, low RDS (on) MOSFET and lower ESR solid capacitors, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte ultra durable 2 edition graphics cards now feature a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
As opposed to the stereotype, Gigabyte is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower.
Avivo could provide vibrant high fidelity, flawlessly smooth next-generation video playback. Avivo technology easily allows your PCs to become digital home media center by its compelling video pipeline design that comprises the latest high definition video hardware acceleration, including H.264 and WMV9.
As a citizen of the global village, Gigabyte exert themselves to be a pioneer in environment care. Give the whole of Earth a promise that products do not contain any of the restricted substances in concentrations and applications banned by the RoHS directive, and are capable of being worked on at the higher temperatures required for lead free solder. One Earth and Gigabyte cares!
- Graphics Processor Manufacturer
- AMD
- Interface
- Memory Size
- 1 GB
- Digital Output
- Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
- Core Clock
- 880 MHz
