Radeon™ RX460 WINDFORCE OC 4G
Powered by Radeon RX460
Integrated with 4GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
Support Full UHD HEVC Encode and Decode
Core Clock
1212 MHz
WINDFORCE 2X Cooling System
The WINDFORCE 2X cooling system features two unique blade fans, 3D active fan functionality, delivering an effective heat dissipation capacity for higher performance at lower temperatures.
Unique Blade Fan Design
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans
Xtreme Engine
Adjust clock speeds, voltage, fan performance, power target can be monitored and tuned in real-time according to your own preference through this intuitive interface.
