GV-R939G1 GAMING-8GD - Gigabyte AMD Radeon R9 390
OC up to 1025MHz core clock by GPU Gauntlet sorting technology
WINDFORCE 2X with dual 90mm unique blade fan
8192MB high capacity memory fulfill the multi-screen and high definition gaming
0dB Semi-Passive Fan with LED indicators.
Stylish Metal Back-Plate
6-Phase GPU power design
Ultra Durable graphics card components
GIGABYTE OC GURU II Supported
GPU Radeon R9 390
Core Clock 1025 MHz
Memory Clock 6000 MHz
Memory Size 8192MB GDDR5
Bus Type PCI Express 3.0
Memory Bus 512-bit
Stream Processors 2816
Memory type 64Mx32
DirectX 11 Yes
DVI Port - DVI-D
DisplayPort x 3
HDMI x 1
3D' 11 - P: 14922 / X: 4661
3D' FS - Default: 10170 / Extreme: 5002
GPU Gauntlet Sorting
With GPU Gauntletâ„¢ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching
WINDFORCE 2X
Dual 90mm Unique blade fan design
The air flow is split through the triangle design at the fan edge, and is guided smoothly through the fan by the special 3D stripe curve design, effectively enhancing the air flow by 23% over traditional fans, whilst reducing air turbulence.
Fan Stop with Intuitive Fan Indicators
Equipped with the latest 0dB Semi-passive fan technology, the fans stop spinning when the GPU is under a set temperature for complete silence.
Featuring LED indicators on the top of the graphics card to provide an instant display of whether the fans are spinning or not.
Stylish Metal Back Plate
Glorious black metal back plate engraved with G1 GAMING logo inspires passion for gaming.
