Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE "Triangle Cool" technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
- Limited edition with Battlefield 4
- WINDFORCE 3X 450W cooling system
- Powered by AMD Radeon™ R9 290 GPU
- Integrated with 4GB GDDR5 memory, 512-bit memory interface
- Features DVI-D*2 / HDMI / DisplayPort
- Core Clock: 1040 MHz
- System power supply requirement: 600W
