90mm LARGE FAN design brings ultimate cooling, efficiency, and quietness.
OC Edition with Core Clock of 1200MHz (Std: 1050MHz)
2GB GDDR5 memory and 128-bit memory interface
Ultra Durable 2 technology delivers lower temperature and longer system lifespan
OC GURU II -- Brand-new intuitive interface helps you easily modify important settings and directly update driver and BIOS.
Chipset - Radeon R7 360
Core Clock - 1200 MHz (standard: 1050 MHz)
Process Technology 28 nm
Memory Clock 6500 MHz
Memory Size 2GB
Memory Bus 128-bit
Memory Type GDDR5
Card Bus PCI-E 3.0
DirectX 12
OpenGL 4.4
PCB Form ATX
Digital max resolution 4096 X 2160
Analog max resolution 2048 x 1536
Multi-view 4
I/O - Dual-link DVI-I1/DVI-D1/HDMI1/Display Port1
Card size H=42 mm, L=159 mm, W=127 mm
Power requirement 500W (with one 6-pin external power connector)
