As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the latest cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower.
- Powered by AMD Radeon R7 250 GPU
- Integrated with the first 2048MB DDR3 memory and 128-bit memory interface
- OC Edition - Core Clock: 1100 MHz (Std 1050 MHz)
- Features Single-Link DVI-D / HDMI / D-Sub
- Support PCI Express 3.0 x8 bus interface
- System power supply requirement: 400W
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
