As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower.
- Powered by AMD Radeon R7 240 GPU
- Integrated with the first 2048MB DDR3 memory and 128-bit memory interface
- OC Edition - Core Clock: 900 MHz(Std 780 MHz)
- Features Single-Link DVI-D / HDMI / D-Sub
- Support PCI Express 3.0 x8 bus interface
- System power supply requirement: 400W
