Manufacturer's Description
This unit contains a powerful Mains Conditioning Filter which will reduce or eliminate mains interference coming through the mains electric supply, enhaincing your sound and picture quality.
Tacima CS929 - MAINS CONDITIONER FOR HOME CINEMA AND HI FIA useful upgrade for any setup this is an affordable yet extremely well designed unit that delivers impressive results. This unit contains a powerful Mains Conditioning Filter which will reduce or eliminate mains interference coming through the mains electric supply and help to enhance your sound and picture quality. It also incorporates Surge Protection for complete piece of mind.Technical notes and performanceThe filters used are specifically designed to combat both Asymmetrical as well as Symmetrical interference both being effectively suppressed by the introduction of High Frequency Capacitors and a single Choke. In addition there is an Earth Line Choke to stop interference through the mains earth line and finally it uses a screened Mains Cable to eliminate the effects of radiated noise interference. SpecificationOperating Voltage 220-250V ac Max Current rating 13A Max Surge Protection L-N 6500A L-E 4500A N-E 4500A Max Voltage Spike Protection 6 000 Volts Neon Indication None- these can inject noise into the system Mains Cable Shielded with Aluminium foil IMPORTANT - The insertion loss measurements below were carried out asymmetrically. Some manufacturers only test symmetrically which appear to offer better resultsSingle stage FilterInsertion Loss dB150kHz.623 MHz.3530 MHz.301 GHz.15Features:2m Screened Mains Lead to prevent RFI Surge protection No neon indicator these can inject noise into your hi-fi and affect the sound quality Earth Line Choke to stop interference through the mains earth line Operating Voltage: 220-240V ac Max Current Rating 13A
Mains conditioner
Surge protection
2 metre screened mains lead to prevent RFI
No neon indicators (these can inject noise into your Hi Fi and affect the sound quality)
WHAT HI FI 5 Star Award
