            Push your limits with the fenix® 8 multisport GPS smartwatch. Featuring a big, bright AMOLED display, stainless steel bezel, and advanced workouts to boost your performance. Enjoy wrist calling with the built in speaker and mic and stay visible with the LED flashlight. Go strong with up to 29 days of battery life.
Built for serious athletes
This advanced multisport GPS smartwatch for athletes and adventurers features a big, bright AMOLED display, stainless steel bezel, enhanced graphical interface and a built-in LED flashlight for after dark visibility.
Reach new fitness levels
Power up your body’s performance, endurance and resistance to injury with targeted strength training plans, real-time stamina tracking, sport-specific workouts and a full range of built-in sports apps.
Long lasting battery performance
Get up to 29 days in smartwatch mode and up to 84 hours in GPS mode.
Track your training
Your training readiness score is based on sleep quality, recovery, training load and HRV status to decide if you’re primed to go hard and reap the rewards. Data presented is intended to be a close estimation of metrics tracked.
Constant communication
For your active lifestyle, a built-in speaker and mic let you make and take phone calls from your wrist when your watch is paired to your smartphone — and you can even use your smartphone’s voice assistant to respond to text messages and more.
Key features
- Advanced multisport GPS smartwatch with a 1.4 inch AMOLED display, stainless steel bezel, enhanced interface, and built-in LED flashlight for after-dark visibility.
- Boost performance with targeted strength training plans, real-time stamina tracking, sport-specific workouts, and built-in sports apps.
- The 47mm model has up to 16 days of battery life in smartwatch mode and up to 47 hours in GPS mode.
- Training readiness score based on sleep, recovery, training load, and HRV status to figure out if you're primed to go hard.
- Built-in speaker and mic let you make and take calls from your wrist and use your smartphone’s voice assistant to respond to texts.
- Off-grid voice command feature lets you access select watch controls without a smartphone connection.
- Navigate with superior accuracy using multi-band GPS, SatIQ™ technology, 3-axis compass, gyroscope, and barometric altimeter.
- Dynamic round-trip routing sets target distance and provides turn-by-turn directions to get you back to your start on schedule.
- 40 metre dive rating and leakproof metal buttons let you reach new depths with support for scuba and apnea dive activities.
