Gainward uses only the highest quality components to ensure excellent stability at extreme conditions. Every single piece of Gainward "Golden Sample" has been applied for critical burn-in tests to ensure the best stability under aggressive overclocking. Gainward GR 8 design Great 8 cm fan achieves highest cooling performance at much lower temperatures under power saving mode.
- GPU : GeForce GTX 550 Ti
- GPU Clockspeed : 1000 Mhz
- Memory : 1024MB GDDR5 192bits
- Memory Clockspeed : 2200 Mhz
- Pixels per clock (peak) : N/A
- Bandwidth : 105.6 GB/s
- Ramdac : 400 MHz
- Bus : PCI-Express 2.0
- Cooling : 2-Slot Fan
- Video-Features : HDMI
- Connectivity : DVI-I + VGA
