The Fujitsu fi-6800 offers fast 130ppm/260ipm, A4 landscape colour scanning with a device that has been developed with a completely new and unique compact design. The design includes both unique image handling hardware and hardware accelerated 'VRS Professional' factory mounted, the user receives a complete high performance capture solution right out of the box. Operators will begin making professional scans in no time.
A new compact design that sure to please users.
Utilizing a high quality lens and extra bright LED light source enclosed in a heavy duty resin frame. The fi-6800s new compact design makes it the smallest document scanner in its class. It takes up 53% less space and is 72% lighter than its predecessor.
Supporting the Operator
-The fi-6800 is ergonomically designed to facilitate scanning whether the operator is standing or seated.
S-canner status and settings are presented and controlled on an easy to navigate LCD panel.
-Simple but very sturdy construction with a wide flip up cover for easy access and obstacle free cleaning.
-Near silent operation allows for front or back office placement in support of a multitude of professional business scanning tasks.
New functions that boost automation and increase productivity
The fi-6800 supports many new automatic functions that simplify your scanning tasks and maximise operator productivity.
Route files with ease, using Patch code or barcode supported job separation
fi-6800 features patch code and barcode recognition functions, Whenever detected, files can be automatically routed to new subdirectories to expidite and automate post capture processing routines. If using barcodes the files and directories can even be named based on the information contained in the barcode. Combined with the images capture software ScandAll PROs automatic sorting function, scanning sorting and saving can be a hands free operation.
Reduce the hassle of post scan tasks
Automatic stacker ensures all your scanned documents are neatly stacked, while an Automatic Image Quality Checker detects an image irregularities i.e. folds or tears in the original document, after scanning. Post scanning tasks have never been this easy.
An improved paper feed mechanism which protects against document damage or misaligned feeds
Fujitsu's fi-6800 features a very reliable paper feed mechanism which is derived from Fujitsu's top-of-the-line fi-5900C model. Utilising fi-series renowned "Paper Protection" and "Multi Feed Protection" functions, paper feed problems are tackled before they happen. This ensures optimum workflow to your business and maximum uptime for the scanner.
Short recovery from sleep mode due to use of extra bright LED source (within 6 seconds)
Going easy on our environment (Green IT)
Low power consumption when in sleep mode (less than 4 watts)
Constructed using minimum quantities and lightweight raw materials
