The ADF only fi-6670 is amongst the fastest scanners in its class, able to capture documents at 90ppm / 180ipm capable (A4, landscape, 200 dpi). Its 200 sheet document feeder allows continuous scanning containing paper of different weights, quality and sizes and the fi-6670 can even scan paper up to 3 m long enabling digitization of electrocardiograms, instrumental data readings and other long documents.
An extremely compact design with small footprint and operating panel on either side extends options for positioning the scanner in the office.
The fi-6670 comes loaded with features allowing the scanner to work autonomously as a true batch document scanner. Intelligent multi-feed function simplifies pre-scanning preparation and improves efficiency by identifying documents that tend to trigger false multi-feed alerts, such as documents with photos or sticky notes attached. The fi-6670 scans trapezoid-shaped documents across their full width, as well as ensuring that index tab and sticky note attached documents are scanned in their entirety. In addition, the fi-6670 removes the circular and angular punch hole representations that are created from scanning loose-leaf sheets, courier service forms and other similar documents.
Excellent scanning performance is possible with the bundled premium version of ScandAll PRO V2 scanning software, which features embedded zonal OCR functionality, multi-streaming options and a wealth of output format including password protected PDF and PDF/A formats. In daily operation tasks the user can be supported by setting up job routine profiles that can easily be ex- and imported by multiple scan stations. ScandAll PRO V2 Premium features job separation and indexing functionality using 2D codes (matrix codes).
The bundled ScandAll PRO image capture software supports advanced functions such as Automatic Job separation, Indexing, Seamless Microsoft Office SharePoint Server linkage and Scanner Central Admin console for network enabled device management.
The fi-6670 also comes bundled with Kofax Software VRS Professional, which simplifies the image capture operation and streamlines automated business processes. It allows information workers to focus on their productive tasks whilst at the same time supporting them by capturing information from paper documents at the click of a button.
