The fi-5015C image scanner from Fujitsu with a USB interface offers high speed, simplex color scanning capabilities within a compact body making it an ideal solution for decentralized scanning applications.
The fi-5015C can be customized to scan directly to email, ftp, print, Adobe PDF, or view with hardware profiles.
Equipped with a powerful 600-dpi true optical resolution CCD sensor, the Fujitsu fi-5015C dual feed scanner captures your document's finest details in both 24 bit color and monochrome. The fi-5015C automatic scanner also features an operator panel allowing effortless scanning directly to print, an email attachment, FTP, Adobe PDF, network share, or to your viewer.
Adobe Acrobat Standard and ScandAll Pro are included with the Fujitsu fi-5015C scanner, which allow you to quickly and easily integrate it into your workflow.
