Enjoy perfect picture quality with 3.7 Mio pixels, outstanding ergonomics and usability as well as comfortable energy saving solutions of this 27-inch widescreen Fujitsu P Line display.
Due to IPS panels Fujitsu P Line displays deliver the best viewing experience always, with ultra-wide viewing angle. They're a delight for your eyes with razor-sharp pictures up to 3.7 million pixels.
0-W power in power save mode
The 0-W power save mode stops energy waste in power save mode. When the PC signalizes off-mode, a switching display element cuts the monitor completely from the power line. An absolutely unique energy saving solution!
ABC - Automatic Brightness Control
A light sensor on the top of the display measures the ambient light and adjusts the brightness accordingly. ABC optimizes ergonomic conditions and saves energy.
Exceeding ergonomics
With focus on ergonomics you prefer a stand, totally flexible for individual adjustments. Best-in-class height-adjust, stunning swivel, tilt and rotation and automatic switch to portrait screen guarantee a healthy, fatigue-free posture during long usage sessions.
Fujitsu P27T-7 LED - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Marble grey
64.4 cm x 22.7 cm x 40.5 cm
9.5 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, C-Tick, GOST, cUL, EN 60950, SASO, TUV S, VESA FPMPMI, CCC, DDC/CI, RoHS, ISO 9241-307, WEEE, KC, Directive 2004/108/EEC
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated
Marble grey
64.4 cm x 22.7 cm x 40.5 cm - with stand
9.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DisplayPort , HDMI , DVI-D (dual link) , VGA , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-in
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 0-Watt technology
1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
30 W
Power Consumption (Typical)
31 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 64.4 cm - depth: 22.7 cm - height: 40.5 cm - weight: 9.5 kg , Without stand - width: 64.4 cm - depth: 7.2 cm - height: 38.3 cm - weight: 6.5 kg
