These days it's all about speed, reliability and flexibility. More and more people work with large files such as DTP/graphical files and uncompressed video and audio. The need for an external hard drive with top speed and top reliability is more present then ever. The Freecom Hard Drive Quattro provides it all. The USB 3.0 interface provides you with the fastest data transfer speed to date for a single external hard drive. Connected to eSATA, the Hard Drive Quattro performs up to 6x times faster than a standard USB 2.0 hard drive.
Since USB 3.0 is fully downwards compatible with USB 2.0 you have the ultimate flexibility - you can connect the drive to any modern computer that does not have an eSATA or FireWire interface.
The Hard Drive Quattro comes in a stylish aluminum enclosure which will compliment the design of your PC or Mac, with the possibility to position it horizontally or vertically on your desk. The Freecom Hard Drive Quattro is pre-formatted so you're ready to use your drive seconds after connecting it to your PC or Mac.
