Boasting wall-penetration and anti-interference capabilities, the dual-antenna C3WN stays on-line better. It's well-equipped to maintain a steady and reliable long-range signal.
With a built-in noise-canceling microphone, the C3WN allows you to hear what's happening in high quality audio. Use your smartphone to listen, wherever you might be.
What is it like to have a night vision camera that can spot objects from as far as 30 meters (100 feet) away and clearly reproduce them in recorded video? Experience it with the C3WN, "seeing" in the dark by using powerful Infrared LED lights.
The IP66 rating means that the C3WN is reliable and durable enough to brave any weather - sun, rain, or snow - relentlessly safeguarding what matters most.
- EZVIZ C3Wn - network surveillance camera
- Network surveillance camera - fixed - outdoor - dustproof / weatherproof
- Audio
- Yes: built-in microphone
- 7.2 cm x 15 cm x 7.2 cm
- 288 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- PS CMOS - 1/2.9"
- Minimum Illumination
- 0.02 lux F2.0 - AGC on , 0 lux - IR
- Focal Length Control
- Fixed focal
- Lens Mounting
- M12 mount
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 12 V
- Progressive scanning, image mirror, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR)
- Environmental Parameters (operating)
- -30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 7.2 cm
- 15 cm
- 7.2 cm
- 288 g
Camera
- Colour - Day&Night - fixed - outdoor - dustproof / weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 30 m
- Frame Rate (max)
Image Sensor
- PS CMOS 1/2.9"
Lens Construction
- M12 mount - fixed focal
- Network Interface
- Ports
- LAN - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Screw kit, waterproof connectors, mounting template
- UL, NOM, FCC, R&TTE, RoHS, KCC, WEEE, REACH, IP66, CE/EMC, FCC-ID
- Power Requirements
- DC 12 V
- Power Device
- Power adapter - external 6 Watt
- Shipping Width
- 25.2 cm
- Shipping Depth
- 11 cm
- Shipping Height
- 9.2 cm
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
