Make 360° protection mobile and reliable
Now, it’s easier than ever to put security in action in the places you care about most. EZVIZ’s newest camera overcomes installation limitations caused by networks or electricity. The EB8 4G is battery-powered with no strings – or cords – attached. It operates on 3G/4G LTE networks in the outdoors where Wi-Fi may not be available. It also inherits key features from EZVIZ's popular outdoor pan & tilt predecessors to provide smart and reliable protection 24/7.
Made for the great outdoors
Wi-Fi and power can be a headache when it comes to outdoor protection. The EB8 4G changes the game by operating with a large battery and 4G network. The camera is weatherproof against rain and snow, and can stay charged using sunlight through a compatible solar panel.
With 4G, it’s portable & mobile
Wi-Fi coverage will no longer be a problem when finding that perfect location to install the EB8 4G. Just install the camera any place with a 4G LTE connection, and move it to another spot whenever you need.(1)
Know where your camera is with the built-in GPS
Even if you lose your camera in the wilderness or the woods, it won't be lost thanks to the GPS locator function
Large battery capacity, with eco-friendly charging options
The EB8 4G is 100% wire-free with built-in rechargeable batteries (3). Going even further into the realm of sustainable green energy, this camera can be connected to an EZVIZ Solar Panel (4) to harness the power of the sun
1 Please note that the EB8 4G camera only operates with a 4G network and does not work with a Wi-Fi connection. The list of supported regions and carriers is continually updated; please find the full list at ezviz.com.
2 The GPS function is able to run properly only when the camera is installed in an open, outdoor environment. If you install the camera in an indoor space inside a building, the GPS may not function properly.
3 The camera battery life may vary due to the stability and/or signal strength of network carriers, environmental factors, and the frequency of camera activities.
4 The solar panel is not included in the kit. Currently the EZVIZ EB8 4G supports connecting with EZVIZ’s specific solar panels with type-C charging ports. Please verify compatibility before making a purchase.
5 Local storage cards must be purchased separately. Cloud storage service is only available in certain markets. Please verify availability before making any purchase.
6 The spotlight will not flash when the Color Night Vision mode is enabled.
7 Data from EZVIZ Lab’s test results under standard conditions. The video compression efficiency will vary with the frequency and complexity of the activity captured, as well as other environmental factors
