Introducing the EZVIZ Pan and Tilt camera
Imagine that you are at work and an intruder has come into your home – your Pan/Tilt Wi-Fi Smart Camera will alert you straight away with a message via the EZVIZ app to your smartphone, take a snapshot and even proceed to record the events and the suspicious activity. What’s more, the camera will track and follow them too, gathering up as much footage as possible.
Baby/Elderly/Pet Monitor
Great for monitoring your pets, little ones or elderly relatives. Furthermore, with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Pan/Tilt & Motion Tracking
With the 340-degree Horizontal, 105-degree vertical rotation Pan & Tilt feature, you can see everything in the room, keeping a lookout of the whole room. If it notices something moving (like the dog with something in its mouth), the camera will track the movement automatically across the room, providing the best footage possible. This can also be manually moved around via your EZVIZ smartphone app.
Be Informed
Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night
The Infrared (IR) allows clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk
The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
What’s in the box
1x EZVIZ HD 1080p Pan Tilt Camera
1x Power Adapter with 3m Cable (3.5mm jack connection)
1x Mounting Accessories and set of screws
1x Quick Start Guide
