90% efficiency or higher under typical loads and the highest quality Japanese brand capacitors ensure long-term reliability.
Semi-modular design allows you to only use the cables you need, helping to improve case airflow, eliminate unnecessary wires, and best of all. reduce cable clutter.
The EVGA ECO mode feature ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
