GeForce GTX TITAN X
The EVGA GeForce GTX TITAN X combines the technologies and performance of the new NVIDIA Maxwell architecture in the fastest and most advanced graphics card on the planet.
This incredible GPU delivers unrivaled graphics, acoustic, thermal and power-efficient performance. The most demanding enthusiast can now experience extreme resolutions up to 4K-and beyond.
Enjoy hyper-realistic, real-time lighting with advanced NVIDIA VXGI, as well as NVIDIA G-SYNC display technology for smooth, tear-free gaming. Plus, you get DSR technology that delivers a brilliant 4K experience, even on a 1080p display.
SPECIFICATIONS
Base Clock: 1000 MHZ
Boost Clock: 1075 MHz
Memory Clock: 7010 MHz Effective
CUDA Cores: 3072
Bus Type: PCI-E 3.0
Memory Detail: 12288MB GDDR5
Memory Bit Width: 384 Bit
Memory Speed: 0.28ns
Memory Bandwidth: 336.5 GB/s
DIMENSIONS
Height: 4.376in - 111.15mm
Length: 10.5in - 266.7mm
Width: Dual Slot
KEY FEATURES
NVIDIA Dynamic Super Resolution Technology
NVIDIA MFAA Technology
NVIDIA GameWorks Technology
NVIDIA GameStream Technology
NVIDIA G-SYNC Ready
Microsoft DirectX 12
NVIDIA GPU Boost 2.0
NVIDIA Adaptive Vertical Sync
NVIDIA Surround Technology
NVIDIA SLI Ready
NVIDIA CUDA Technology
OpenGL 4.4 Support
OpenCL Support
HDMI 2.0, DisplayPort 1.2 and Dual-link DVI
PCI Express 3.0
RESOLUTION & REFRESH
Max Monitors Supported: 4
240Hz Max Refresh Rate
Max Analog: 2048x1536
Max Digital: 4096x2160
REQUIREMENTS
500 Watt or greater power supply.(1)
PCI Express, PCI Express 2.0 or PCI Express 3.0 compliant motherboard with one graphics slot.
An available 6-pin PCI-E power connector and an available 8 pin PCI-E power connector
Windows 8 32/64bit, Windows 7 32/64bit, Windows Vista 32/64bit
(1)Minimum sy stem power requirement based on a PC conf igured with an Intel Core i7 3.2GHz processor.
PRODUCT WARRANTY
This product is covered under EVGA's 3 year warranty which covers parts and labor. Further warranty extension is available upon registration within 90 days of purchase. For more details please visit www.evga.com/warranty
