GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
If you're looking for hyper-realistic gameplay, stunning visuals, and exceptional value, this is your graphics card.
SPECIFICATIONS
- Base Clock: 1189 MHz
- Boost Clock: 1268 MHz
- Memory Clock: 5400 MHz Effective
- CUDA Cores: 640
- Bus Type: PCI-E 3.0
- Memory Detail: 2048MB GDDR5
- Memory Bit Width: 128 Bit
- Memory Speed: 0.4ns
- Memory Bandwidth: 86.4 GB/s
KEY FEATURES
- NVIDIA® TXAA™ Technology
- NVIDIA GPU Boost 2.0
- NVIDIA® PhysX® Technology
- NVIDIA FXAA™ Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA® Surround™
- Support for three concurrent displays; dual-link DVI, HDMI** and Displayport 1.2
- Microsoft® DirectX® 11.2 API (feature level 11_0) with Direct Compute 5.0 support
- NVIDIA 3D Vision®-Ready*
- NVIDIA CUDA® Technology
- PCI Express® 3.0 Support
- OpenGL 4.4 Support
- OpenCL™ Support
- NVIDIA SHIELD™-Ready
- NVIDIA G-SYNC™-Ready
REQUIREMENTS
- 500 watt or greater power supply with a minimum of 30 amps on the +12 volt rail.**
- PCI Express®, PCI Express® 2.0 or PCI Express® 3.0 compliant motherboard with one graphics slot.
- Microsoft® Windows 8 / 7 / Vista / XP
DIMENSIONS/WEIGHT
- Height: 4.376in - 111.15mm
- Length: 9.5in - 241mm
- Weight: 1.35lbs
ACCESSORIES
- EVGA Driver/Software Disc
- (1) DVI to VGA Adapter
- EVGA Accessory Pack
- User Guide
