The powerful new GeForce GT 600-series architecture delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that will transform the way you experience all your favorite titles now and in the future.
Key Features
- Microsoft DirectX 11 support: DirectX 11 GPU with Shader Model 5.0 support designed for ultra high performance in the new API's key graphics feature, GPU-accelerated tessellation.
- NVIDIA CUDA technology: CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
- NVIDIA PhysX technology: Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
- NVIDIA PureVideo HD technology: The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
- PCI Express 2.0 support: Designed for the new PCI Express 2.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
- Dual-link HDCP-Capable: Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc format, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays.
- Microsoft Windows 7 Support: Windows 7 is the next generation operating system that will mark a dramatic improvement in the way the OS takes advantage of the graphics processing unit (GPU) to provide a more compelling user experience. By taking advantage of the GPU for both graphics and computing, Windows 7 will not only make today's PCs more visual and more interactive but also ensure that they have the speed and responsiveness customers want.
OpenGL 4.0 Support: Ensures top-notch compatibility and performance for OpenGL applications
Performance
- NVIDIA GT 610
- 1536 CUDA Cores
- 810 MHz GPU
- 1024 MB, 64 bit DDR3
- 1000 MHz (effective)
- 8 GB/s Memory Bandwidth
- PCI-E 2.0 16x
- DVI-I, HDMI, VGA
Resolution & Refresh
- 240Hz Max Refresh Rate
- 2048x1536 Max Analog
- 2560x1600 Max Digital
Product Warranty
- This product comes with a 3 year limited warranty. Registration is recommended
Operating System Support
- Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
Requirements
- Minimum of a 300 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 16 Amps.)
