When building on a budget, the EVGA 500W 80 PLUS is a great choice at a low cost. Supporting 40A on a single +12V rail provides more options without having to reduce your component requirements. Save space with the 500W's compact design, well-placed power switch and fully sleeved cables. The 500W offers the connections and protections needed for basic system builds. With a standard 3 year warranty and ultra quiet fan design the 500W will be a great asset for your next build on a budget.
CABLE LENGTH
- ATX CABLE 1x 550mm
- EPS CABLE 1x 600mm
- PCIE CABLE 1x 550mm, 670mm
- SATA CABLE 2x 450mm, 570mm, 690mm
- FOUR-PIN PERIPHERAL CABLE 1x 450mm, 570mm, 690mm (f)
- FLOPPY CABLE 1x 120mm
- AC POWER 1x 1200mm (m)
FEATURES
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
- 3 Year Warranty
- Quiet and Intelligent Auto Fan for near-silent operation
