With price and performance in mind, the EVGA 500B is the best value power supply for your next build on a budget. With 80 Plus Bronze standard, over 80% efficiency under typical loads, the EVGA 500B is a great choice. Combining 500 W of continuous power and Single +12 V High AMP rail design, gain maximum power and efficiency while staying protected with a series of over volt/over current protections all bundled into one!
