High-speed scanner
The DS-520 has a compact footprint and high-speed scanning of up to 30ppm / 60ipm, even at 300dpi in both color and monochrome. This, combined with hardware JPEG compression, makes large scan jobs faster to process. With the optional Network Interface Unit, it is ideal for sharing across office and department networks.
Document workflow
Epson Document Capture Pro and Document Capture Pro Server¹ make it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document repositories. In addition, barcode recognition and Zonal OCR helps automate large document processes, such as file naming and folder creation. It's easy to integrate thanks to TWAIN, ISIS and WIA driver support.
Efficient
Epson's scanning software offers a wide range of advanced document imaging features, including multi-document size detection, text enhancement and automatic de-skew to improve efficiency and increase productivity.
Optional Network sharing}
Add the optional Network Interface Unit to easily integrate into your company environment. Combined with Document Capture Pro/Pro Server¹, the networked model increases employees productivity with customisable PushScan functions from the scanner panel such as scan-to Microsoft SharePoint and cloud services.
