            It's easy to scan and manage your paperwork on the go with the DS-310. Its compact and lightweight design means that it's ideal for carrying in a bag or even storing in a drawer. Give yourself the flexibility to scan what you need, when you need it. With the DS-310, you can capture documents at 300dpi in color and monochrome with absolute ease. When it comes to media, it's almost limitless with both single and double-sided scanning, and the ability to handle card and paper between 52 and 230gsm.
