Back
Printers & Multifunction
Epson TM U220A Colour Dot-Matrix Receipt Printer
Quicklinx:
7N68WS00
Mfr#:
C31C516057
Back
1ST IMPACT PACKAGED PRINTER * PS, NES; Parallel; Epson Cool White (ECW); Power Supply.
Easy-to-use impact printer
If you need a hard worker that's easy to use and versatile, this is the ideal impact receipt printer.
Epson TM U220A - receipt printer - colour - dot-matrix
Printer Type
Receipt printer - dot-matrix - 9 pin - colour
2.7 kg
Max Media Size
Roll (7.6cm)
Max Media Size (Custom)
76 mm
Print Speed
Up to 6 lines/sec - max speed , Up to 4.7 lines/sec - colour
Max Resolution (Colour)
17.8 cpi
Cutter
Parallel
Media Type
Labels
Fonts
2 fonts
Total Media Capacity
1 roll
Enclosure Colour
Dark grey
16 cm x 28.6 cm x 15.8 cm
Printer Type
Enclosure Colour
Dark grey
Printer
Print Speed
Up to 6 lines/sec - max speed - 16 cpi , Up to 4.7 lines/sec - colour - 16 cpi
Built-in Devices
Cutter
Wired
Parallel
17.8 cpi
Fonts
2 fonts
Character Sizes (mm)
1.2 x 3.1 mm, 1.6 x 3.1 mm
Columns
33, 35, 40, 42
Auto Cutter
Media Handling
Media Type
Labels
Max Media Size
Roll (7.6cm)
76 mm
Media Sizes
Roll (7 cm), Roll (7.6cm), Roll (5.8 cm)
Media Thickness Range
0.06 mm - 0.085 mm
Roll Maximum Outer Diameter
83 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (7.6cm)
Max Sheets in Multi-Part Form
2
1 x parallel
Take-up reel
MTBF
180,000 hour(s)
FCC Class A certified, CSA, UL, TUV, EN 60950, VCCI Class A ITE
Power adapter - external
16 cm
28.6 cm
15.8 cm
2.7 kg
