Ideal for graphics, CAD and GIS
The SureColor SC-T3200 is one of the SureColor SC-T series of high-speed, four-color large-format printers, designed to produce a wide range of high-quality graphics, CAD and GIS applications in design, commercial print, copy shop, architecture, building, engineering, retail and education environments.
Highly productive
To maximise productivity, the SureColor SC-T3200 features 1GB of RAM for ultra-fast image processing, and an optional 320GB HDD for job caching and recall. Optional PostScript support with dual 1.6GHz CPUs enables printing of large data-rich files quickly and directly from leading design and CAD programs. And the SureColor SC-T3200 is fast — outputting an A1 print takes just 28 seconds.
High quality output
The combination of Epson’s PrecisionCore TFP printheads and UltraChrome XD pigment ink delivers industry-leading output quality and precise, repeatable performance. UltraChrome XD pigment ink is smudge and water resistant and delivers deep blacks and crisp, dense lines — ideal for technical graphics — and the vibrant colors necessary for high-quality prints and posters, on coated and non-coated media — including board up to 1.5mm thick.
Compact, quiet and easy to use}
With its sleek styling, compact footprint, low noise levels and front operation, the SureColor SC-T3200 is designed to fit easily into an office environment.
