This no-nonsense printer is perfect for all your home documents and photos and saves you money with individual ink cartridges. This reliable, economical printer makes home photo and document printing simple and effortless. Prints look great and last longer on any paper because Epson DURABrite Ultra ink is water, smudge, fade and even highlighter resistant. You can remove red-eye and adjust colour and contrast in a fl ash with the included software to ensure your photos always look their best. Individual ink cartridges save you money as you only replace the colour used, and this power-efficient ENERGY STARĀ® qualified printer will also help to reduce your energy bills and environmental impact.
Key Benefits
- Individual ink cartridges: - Save money by only replacing the colour used
- Epson DURABrite Ultra Ink: - Produce high-quality documents with our high-quality ink
- Epson PhotoEnhance: - Automatically adjusts colour and contrast for perfect results
- Remove red eye: - Epson Easy Photo Print removes red eye from your images
- Up to 5760x1440 optimised dpi - on suitable media using RPM (Resolution Performance Management)
- Clean design: - Smart and discreet, will easily slot into any space
Box Contents
- 4 individual ink cartridges
- Software CD
- 'Start Here' guide
- Warranty document
- Power cable
