Ideal for photo printing
For anyone who isn't willing to settle for just lab-quality results when printing their photos, Epson's unique Claria Photographic Ink has been developed to deliver better-than-lab-quality results with every print job. You get great value with a choice of cartridge sizes and, with individual inks, you only need to replace the color used. The ideal partner for the latest DSLR and compact cameras, high-quality prints can be achieved every time with this high-definition ink that's also versatile enough for the whole household to use for their non-photo printing needs. Additionally, the dual paper trays allow you to effortlessly switch between A4 sized and photo sized paper during printing, by automatically selecting the correct tray.
Automatic Wi-Fi set-up
Configuring laptops and computers to print wirelessly is much easier with the automatic Wi-Fi set-up*1. You don't need to know your network settings or connect with a USB cable, the PX730WD automatically finds the relevant connection settings and configures itself. Multiple users then have the freedom to print, copy and scan quickly and efficiently from anywhere in the home.
Mobile printing
The PX730WD is also compatible with Epson iPrint which offers even more flexibility and freedom, allowing you to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs*2.
Ease of use
The smart-navigation touch-panel highlights relevant buttons, guiding you through the printing process, while the large 6.3cm colour LCD screen and accompanying PictBridge and memory card slots offer easy-to-use PC-free photo printing. No more waiting for computers to power up; printing directly from a memory card allows greater flexibility and is straightforward. The front-loading paper trays offer easy access while keeping the paper neatly out of sight.
High performance
This highly efficient all-round printer comes with fast print speeds and double-sided document printing. It also has the ability to print directly onto suitable CD and DVDs, which you can use to personalise family films and digital photo albums to create homemade gifts.
