Assignable Tap Function
Runsense provides you with flexible features and controls, like the tap functionality that allows you to scroll through four customisable screens - providing real time data- turn on the light or set laps.
Customise the four displays your way with up to three measurements per screen. You can even select and save settings through the Run Connect app making it quick and easy to customise your device for specific workouts.
