Design labels easily
Creating labels is easy using the included software with intuitive menus. Choose from pre-loaded label templates, or design your own and store them on your computer. A special toolbar enables you to add pre-defined frames, symbols, barcodes and text enhancements, or import images. In just a few steps, your label is ready to print.
Import and print data
Using the software, you can import data in csv, txt and xls(x) formats, create a layout corresponding to the column headings, and then print labels for each line of data. You can also print a series of labels with incremental dates or figures.
Convenient
Producing labels is a hassle-free process from start to finish, as the LW-900P automatically detects the tape width, and automatically cuts or half-cuts the labels once printed. Its convenient integrated trimmer can round label edges, and a dedicated window displays how much tape remains.
Flexible tape options
Epson's wide selection of labels in 6, 9, 12, 18, 24 and 36mm sizes cover virtually every labelling need, with transparent labels, cable wraps, writable matte paper labels and more, plus a choice of adhesive strengths and colour combinations. All Epson labels are very durable, resisting water and withstanding hot and cold conditions.
Economical
The LW-900P minimises label margins, meaning you get more labels per tape, and Epson's 9-metre label tape offers economical refills. Two four-metre label tapes are included to get you started.
