Connect the LW-700 to your computer and you can create labels the way you want to, thanks to the included Label Editor Software. Design your own labels and store them on your computer, or choose from a variety of templates.
Using a special toolbar, you can add frames, symbols, barcodes and images for full customisation. With the data import function you can also choose to print one label up to 999 times, or 999 different labels, in a single print job – ideal for large office projects.
Unplug the LW-700 from your PC, and your desktop model instantly turns into a portable label maker. You can easily create labels away from the office thanks to its embedded keyboard, a wide variety of functions, dedicated access keys and carry handle. With its print-preview graphic display, you can see what your labels will look like before you print them, saving you time and money on unnecessary printing.
Choose from the large collection of 460 symbols and, with the ability to save up to 100 designs in the internal memory, you'll always have the right designs when you need them. Margins can be minimised down to 1mm, meaning you get more labels per tape, and you can print labels up to 24mm in width.
To help get you started, the LW-700 is supplied with one nine-metre tape while the large variety of tapes available ensure you're able to select the ideal tape for your particular task.
