Quick work:
Work fast with speeds up to 18 ppm in mono and 12 ppm in colour. Make the whole process one-touch simple by customising the controls for scanning to any folder or application.
Save energy:
With Epson ReadyScan LED technology you can start work as soon as you turn on, and you’ll make less of an impact on the environment because the scanner uses a lot less energy.
A perfect match:
With TWAIN/ISIS support this scanner is an easy fit with your document management system. Epson Event Manager is part of a software package that smooths the whole scanning process.
