Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge. The use of individual ink cartridges means only the colour used need to be replaced to help save on ink costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use features
For maximum control, the XP-630 comes with a tilting control panel and 6.8cm LCD screen with touchpad for easy navigation. Dual paper trays, one for A4 and one for photo paper, and fast, double-sided printing helps save time. Users can also simply slot in a memory card and follow the helpful menu prompts to print photos without a PC.
