Easy sharing
It's never been easier to take what you're seeing on a smart device and share it with a larger audience. The iProjection QR function means that any smartphone or tablet with the free iProjection app can scan the QR code projected by the EB-W28 to instantly connect and share content .
Unbeatable image quality
With WXGA resolution, 10,000:1 contrast ratio and 3,000 Lumens brightness, 3LCD technology ensures crisp images and equally high White and Colour Light Output for bright and vivid colours, and three times brighter colours than leading competitors .
Portable design
The EB-W28 can easily be carried between meeting rooms, or installed in boardrooms.
Flexible placement
A 1.2x optical zoom and horizontal and vertical keystone adjustment makes it easy to adjust your image for your environment.
Business-centric features
Easy comparisons in meetings are possible using the split-screen functionality. Multi-PC Projection software allows moderator control and up to 50 users to share content, and Epson Network Projection provides sharing of customised settings across a fleet of projectors.
Easy installation in meeting rooms
The OSD (On Screen Display) menu setting copy feature and the ability to update firmware via USB make it easy to set-up and maintain multiple projectors in a number of meeting rooms.
