Flexible
The projector has a stylish, modern1 design and is compact and lightweight to offer the flexibility of both installation and mobile use. With a short throw distance, producing large screen sizes from a short distance, with a 68-inch screen size from a distance of just 2m. This allows you to make better use of table space, as you no longer need to accommodate the projector in the middle of the table. The direct power on/off feature enables the projector to be activated using a wall switch. When using as a portable projector, the instant-off function means no cool-down time is required, allowing you to pack up and go without delay.
High-quality image
There's no need to use this WXGA projector in the dark as it combines a White and Colour Light Output of 2,600 lumens, 3LCD technology and a 3,000:1 contrast ratio for great picture quality, natural-looking images and excellent brightness. You'll never miss any of the detail either, as the WXGA widescreen resolution (1280x800) will show everything that's on your wide-screen computer without need for adjustments.
Low running costs
A long lamp life of 5,000 hours (in eco mode) helps cut maintenance time and keep running costs low. This projector includes a smaller, brighter, and more efficient E-TORL lamp for clearer and sharper projector images.
Secure
Security is no longer an issue, as a button lock, password lock, Kensington lock, and security bar are in place to protect the projector from unauthorised use. Similarly, company logos can be incorporated into a custom start-up image to replace the standard Epson logo, alerting any unwanted users to the owners' identity, making it clear who the device belongs to.
