High quality, bright and vibrant images
This LCD projector effortlessly displays bright images with vivid colours for a crisp, clear picture: ideal for presentations and moving images, and is aided by the 10,000:1 contrast ratio. With an HDMI input, high definition video and audio content are easily played with the same high quality you would expect from the world's number one projector manufacturer .
Colour Light Output (CLO)
CLO is an important way of measuring a projector's ability to deliver colour and, like all Epson projectors, this model has an equally high White and Colour Light Output for a bright picture with vivid colours.
User-friendly
Thanks to its manual keystone slider – unique to Epson – and automatic vertical keystone correction, this projector is quick and simple to set up. No matter the angle of the projector, you can easily align the projection to ensure a straight and correct image. The Colour Universal Design makes operating the projector easier, thanks to new LED colours and menu icons on the projector's control panel.
Wireless projector
The optional wireless connectivity allows you to show content easily from a range of devices without being connected to the projector via a cable.
Eco-friendly
The EB-S18 features an eco tab setting, auto lamp dimming function and an A/V mute timer.
