The Epson EB-G6050W boasts superior picture quality, ensuring the best possible projection for important presentations. The Colour Uniformity function compensates for unequal colour distribution by adjusting the intensity of RGB on individual areas of the screen.
New and innovative features are designed to offer the best possible presenting tools. The projector can be rotated vertically by 360 degrees so the projection image can be easily moved around the room.
The Epson EB-G6050W is easy to set up and use, thanks to a variety of user-friendly installation features. Pixel alignment, for example, enables the user to align pictures easily and effectively during set up for clear, correct images. With edge blending, a large, widescreen image can be projected from a number of projectors working together seamlessly. Its powerful zoom lens, as well as manual vertical keystone correction and centred lens, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
With the HDMI input, a variety of high definition devices can be connected to deliver HD-Ready content effortlessly.
For simpler integration, this model is also compatible with the Epson EB-G5 series lenses .
