First-class picture quality: Audiences will enjoy perfect images, natural colours and brightness of 5,200 lumens white and Colour Light Output, thanks to Epson's 3LCD technology. Deeper blacks are created with the high contrast ratio of 2000:1.
Wireless connectivity: Wireless connection (802.11 a/b/g).
EasyMP Network & Control: Monitor the status of your projector, email the administrator and set up alerts, so the projector emails the administrator in case of any issues. You can also broadcast a message to the network with the included EasyMP Network Projection software.
Split screen: Compare and contrast data such as graphics or worksheets.
Straightforward set-up: Keep installation simple with the centrally positioned lens, while placement options are broadened with the vertical and horizontal lens shift. The bayonet mount and wide 1.8x zoom ratio with the standard lens make positioning the projector a hassle-free process.
Reliable and low maintenance: Product durability is assured while total cost of ownership is kept to a minimum with the C Fine Inorganic LCD panel and long-lasting lamp.
