High quality, bright and vibrant images
This LCD projector effortlessly displays bright images with vivid colours for a crisp, clear picture: ideal for presentations and moving images, and is aided by the 10,000:1 contrast ratio. With an HDMI input, high definition video and audio content are easily played with the same high quality you would expect from the world's number one projector manufacturer .
Wireless and Ethernet projector
The Ethernet connectivity lets you control the projector and display your content across a LAN network4, while the optional wireless lets you to show content from a range of devices without being connected to the projector via a cable.
More control and collaboration
With the moderator function, you can easily allow others to connect and share their content from wireless devices or over your LAN. You remain in complete control and can choose when to display content – ideal for interaction in a collaborative teaching or training environment.
User-friendly
Thanks to its manual keystone slider – unique to Epson – and automatic vertical keystone correction, this projector is quick and simple to set up. No matter the angle of the projector, you can easily align the projection to ensure a straight and correct image. The Colour Universal Design makes operating the projector easier, thanks to new LED colours and menu icons on the projector's control panel.
