The EB-2265U has wireless connectivity as standard to give you enhanced freedom and flexibility. Support for HDBaseT provides Full-HD video, audio and Ethernet, while the HDBaseT cable allows control from 100 meters away in networks installed with Category 5e cable and above. A smart solution for large venues.
Gesture Presenter
The projector can be manipulated by simply moving your hand in front of it, making smarter, smoother presentations an instant reality.
One-button setup
Thanks to the EB-2265U's one-button setup, making adjustments to screen fit and vertical or horizontal keystone correction are quick, simple and require no expert training.
Epson EB-2265U - LCD projector - 802.11n wireless / LAN / Miracast - white
LCD projector - 1080p
White
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Contrast Ratio
400:1 / 15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video IEEE 802.11n wireless / LAN / Miracast
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
450 watt
37.7 cm x 29.1 cm x 11 cm
4.9 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Brightness (Reduced)
3800 lumens
Contrast Ratio
Image Size
127 cm - 762 cm
Projection Distance
1.5 m - 9 m
Throw Ratio
1.38 - 2.28:1
Digital Zoom Factor
1.6x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 watt
Bulb life cycle
sRGB colour profile, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x HDMI - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
450 watt
Power Consumption Stand by
0.5 watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
