Up to 280-inch display and outstanding quality
HD-ready WXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 280 inches.
Simple set-up and connectivity
Offers auto power-on and an array of connectivity options including two HDMI connections and built-in wireless LAN connectivity to stream content from laptops or mobile devices. Compatible with iProjection software for easy connectivity and content sharing.
Keep costs down
Project for longer with improved reliability and a longer lamp life of up to 12,000 hours in eco mode.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as choosing connection sources. Wireless connections can also be made easily using the information on screen.
Value added flexibility
The Multi-PC projection software bundled with the EB-2142W makes it possible to connect with up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
