Convenient use
The Epson EB-1965 combines high-quality output, value-added features and affordability, into a compact and portable projector. It is perfect for corporate or educational use, as it can be easily installed in meeting rooms or used portably from a desktop.
High quality picture
Utilising Epson's 3LCD technology to ensure clearly projected images, the EB-1965 produces vivid, natural colours and an equally high White and Colour Light Output, even in daylight.
The EB-1965 boasts Wi-Fi connectivity and a DisplayPort connector, allowing you to show high definition audio and video content with ease.
Easy calibration
New to Epson is the convenient 'focus help' feature, which calibrates using a test pattern to allow any meeting room set up to be catered for quickly and easily. This process is made even easier with a wide controller manufacturer compatibility, so the EB-1965 can integrate into an existing system with ease. Also new to Epson is real time auto vertical and horizontal keystone correction, adjusting images in real time, with visible results in seconds. When used with the screen fit function, which corrects images to any framed screen within seconds, calibration of the EB-1965 is quick and simple.
Enhanced productivity
Productivity can be greatly increased with a range of features available with the EB-1965, with the Multi-PC feature allowing content from up to four computers to be shown.
