High brightness: Powered by 3LCD technology, the projector delivers a vibrant, high-quality XGA picture, thanks to an equally high White and Colour Light Output of 4,000 lumens and a contrast ratio of 2,500:1
Easy to use: Setting up the EB-1880 is easy. The projector automatically searches for the picture source, so you don't need to do anything after plugging in your laptop. Aligning the picture takes just seconds as vertical keystone correction is automatic and horizontal keystone can be adjusted using an intuitive slider.
Helpful features: Sound is provided by a built-in speaker delivering up to 10W, while the clever 3-in-1 USB display feature means just one cable is all that's needed for audio, visual and mouse control.
Outstanding versatility: The EB-1880 has a wide range of inputs, including HDMI, and features a direct connection for Epson's ELP-DC06 USB document camera.
Great flexibility: Light and compact, the EB-1880 is ideal for ceiling or desktop installation, while the projector's extra-long adjustable foot means it's suitable for low tables too.
Low cost of ownership: Low power consumption and a long lamp life combine to deliver a low total cost of ownership, while remote network management helps keep maintenance costs down by removing the need for physical checks.
