Discproducer Ink Cartridge, Light Cyan
Ink type: Dye ink
Capacity: 1000 discs or more for 1 inkset in continuous printing under the following conditions:
Environment: At room temperature
Printable area: F116 to 45 mm
Area coverage of each color: 16.7 %
Disc type: CD/DVD
Mode setting: Fine
Color correction: Natural color
Valid period: Specification 2 years, including 6 months after the pack is opened.
Size: Width (W) 42 mm, Depth (D) 83 mm, Height (H) 26.4 mm
Mass: Approximately 64 g.
