High-quality results at speed: Increase the productivity of your business by printing at high speeds of up to 23 pages per minute in both mono and colour, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi.
Effortless integration: Designed to fit seamlessly into complex IT environments, the AcuLaser C2900N comes network-ready with numerous interfaces and emulations for easy integration, including Gigabit Ethernet, IPv6, Adobe PostScript 3 and PCL 5c/6.
Customise your printer: You can choose from a variety of options to fit your business needs. Make your printer even more productive with an additional 250-sheet paper tray to increase capacity to 500 sheets, while optional double-sided printing can cut paper use and costs by up to 50 percent. A high standard memory of 256MB can be increased by an additional 512MB to further boost performance.
Economical printing: The AcuLaser C2900N offers great value for money and its ENERGY STAR-qualified reduced power consumption helps businesses to further cut total cost of ownership and environmental impact.
