The XP4006 rechargeable battery is the perfect portable charger for smart phones and tablet with USB input port! The dual USB output design can charge two devices at once, XP4006 got all the support you need for your power hungry gadgees.
Powerful
4000 mAh battery for extra power
LED Light Indicator
Smart LEDs show battery and charging status.
Portable
Conveniently small and lightweight.
Rechargeable
Up to 500 times
Specs
Battery Type - Lithium Polymer
Battery Capacity - 4000 mAh
Input Specification - 5V, 1A
Output Specification - DC 5V, 1A / DC 5V,2.1A
Weight - 109g
Dimensions - 7.4(L) x 5.8(W) x 2.1(H) cm
