The MiHome Double Wall Socket is a radio controlled unit with individual power switching for each socket. Switching is initiated either by radio control signal or manually by pressing the button on the housing.
Energenie Mi|Home Double Wall Socket - socket switch - white
Socket switch
Environment
Indoor
Functions
Turn power on/off
Wireless
Frequency Band
433.92 MHz
White
United Kingdom
1-year warranty
14.5 cm x 3.3 cm x 8.5 cm
Socket switch
Environment
Indoor
Functions
Turn power on/off
Wireless
Max Range Indoors
25 m
Frequency Band
433.92 MHz
In-wall mountable, on / off button, LED indicator, up to 3000 Watt (each socket) OOK modulation
Product Material
Plastic
White
United Kingdom
Nominal Voltage
AC 230V
Warranty
1-year warranty
BS 5733, IP20, DIN EN 61058-1, EN 301 489-1, EN 62479, RTTE
